Results 1 to 9 of 9
Thread: Twin plug mfi ignition question
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Looking for some advice/guidance/opinions on what the ignition system might look like so that I might install the components before the engine goes in. The project came with the pricey twin plug distributor so that component is already in place. Was actually leaning towards a couple of factory Bosch CDI units mounted in the usual location.
    additional details...the chassis was originally a 72 T, carbureted I believe and has the original wiring harness shown in the photo. Don't know anything about the engine harness and whether it is for an mfi motor or the carbureted version
    Any known potential faults with this approach?
    Can I use some/most of the engine wiring harness?
    Am I better with 3 pin or 6 pin units?
    Factory coils?
    Just some of the questions that eventually need an answer. Thanks for any help along the way. Mike
    Name:  interior painted (7).jpg
    What kind of distributor? And what kind of trigger in the distributor, will guide your choice.
    Apr 2014
    New York/Florida
    I'll get that info tomorrow, parts are located in different shops
    Feb 2012
    Kolham, Groningen, The Netherlands.
    Twin spark wiring harness
    Mike,
    If you need a Twinspark harness, i can help you.
    We manufacture them 3 or 6 pole in standard lengths but also custom to your specifications.
    Regards from the Netherlands.
    Name:  Magneti Marelli Twinspark 3 pole CDI harness small.jpg
    Name:  Magnetti Marelli Twinspark 6 pole CDI harness small.jpg
    Aug 2007
    Phila Pa. area
    Mfi
    1972 cars, T, E, & S used MFI.
    Mike
    in europe some were carbed with zeniths
    Apr 2014
    New York/Florida
    will let you know as soon as I can get it sorted, thanks
    Quote Originally Posted by gerakroo View Post
    Mike,
    Apr 2014
    New York/Florida
    here's the distributor...all parts labeled Germany....wonder what a replacement rotor costs Name:  distributor twin plug (2).jpg
Size:  135.8 KBName:  distributor twin plug (2).jpg
Size:  135.8 KBName:  distributor twin plug (1).jpg
    Based on the pick-up, 6 pin or equivalent ignition.
