Results 1 to 2 of 2
Thread: Need help with seat re-assembly
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    I'm in the process of rebuilding my standard driver's seat on my 1969 911S. Can someone please tell me how the splined crossbar is oriented in each side bracket? Are the side brackets connected to each other in the same orientation or are they offset to each other by, say, 90 degrees?
    Many thanks, as always,
    Alan
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Aug 2009
    SF Bay Area
    The inner hinge just follows the outer hinge. Just get the two parts parallel, install the cross bar, and you are good to go.
    Jim
