Does anyone know if someone makes a cruise control specifically for early 911?
I know I can get a generic unit and adapt, was hoping someone has done the hard work for me.
Cheers
Mitchell
HK RHD 1971T Mongrel
Mitchell,
Besides the hand throttle you already have in the car ?.... You know, that's the 'cruise control' with NO bells and whistles that's REALLY dangerous...
I've used it a few times in the last 25 years..... It will keep you on your toes.......
Yes Chuck, apart from that one
The same thing but with an electronic brain so I can 'set and forget' on the highway (and protect my licence)
Cheers
Mitchell
Its called a "Singer"
Early 911S Registry #750
1970 911E - The Good Stuff
2001 Toyota Landcruiser
I always thought that if you held the gas pedal all the way down a Porsche would travel at its "cruising speed."
Jim Alton
Torrance, CA
Early 911S Registry # 237
1965 Porsche 911 coupe
1958 Porsche 356A cabriolet
That's the autobahn cruising speed (or in Australia the Northern Territory cruising speed) but sadly where I live the roads are speed limited.
Too bad Singer only sell whole cars and not a range of the tasty bits they put in them.
Cheers
Mitchell
Something tells me Ed Mayo has probably run into this question during the last 1/2 century.........
If he doesn't have the answer I bet he'll at lest have a great response..........
I'm sure you can retrofit the system from a Carrera or SC, although it would take some doing and depend on the engine in your car.
Not sure anything other than OEM Porsche would be a good idea.
-Marco
TLG Auto: Website
Good call Ed. Been there done that too. Given that there is a 2 metre throttle rod running the length of the car in a roomy tunnel I can't see why it shouldn't be possible. I will do my best, post the results and leave it to others to judge success or failure.
Cheers
Mitchell
