Thread: space saver tire
    Jun 2011
    Bellingham, WA
    space saver tire
    I have a 72 with 185/70-15 tires on 15-6J rims. What size rim do I need for a space saver tire?
    Tom
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    the same size as you have - but they are really hard to mount
    what spare do you currently have/
    you may be better trying to source a wheel with a good space saver already on it
    they are available from cars up until the late 80's, although the later ones come with different (double) valve stems to stop people from over inflating them but apart from that there is no difference. however i think there were different offsets for different cars - that would be all you would need to look at
    i have had spacesavers mounted on "flat" Fuchs 6x15's twice and both times it was difficult - but not as difficult as taking them off. I have been told by the tyre guys that space savers will not mount to a "deep 6" though.
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    May 2005
    Oroville, CA
    The spacesavers usually came with 5.5 steel wheels but there is some evidence that they also were used on 6X15 Fuchs and 6X15 ATS (in period photos)
    BTW, if you or your tire guy needs a tutorial on how to remove and remount them, I will tell them.
    We did more than 30 in a row and found a solid way of removal without much difficulty...
    and I have seen them on deep 6s but they usually fall off of the inflation area and won't pump up properly.
    H
    Dec 2004
    Melbourne Australia
    my one that came with the car from new is mounted on a steel 5 1/2 x 15 steel wheel (see picture) and the one i use in the car (in case i have to use it rather than look at it given the tire is now over 40 years old) is on a 6x15 Fuchs
    Hugh Hodges
    73 911E
    Melbourne Australia
