Results 1 to 10 of 10
Thread: What Heater Cables Do I Need?
    I'm rebuilding the heating system on my '71T coupe and can't seem to sort out which cable length/part number etc. I need for the actual cables (the piano wire type cables specifically). I'm having difficulty finding the pieces in PET but I think I need 2 cables that run from the heater lever at the shifter base to the flapper boxes. I've got the flappers boxes in the works and I'm ordering new cable guide tubes and rubber end grommets so all I think I need are the cables (original orange hoses are still serviceable). Any help would be appreciated and thanks in advance,
    Stretch
    Registry # 3063
    It is one cable with a 180 degree bend at the heater lever. The bend is not quite in the middle of the cable, the longer side goes to the 1-2-3 side of the engine.
    Ed,
    Thanks for the reply, still a little confused though. It's one cable not two since there are 2 cable guides under the car? Do you know the part number for this cable? Thanks,
    Stretch
    Registry # 3063
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Yes, it's one cable. It's a big V, joint part at the lever each end goes out it's own guide.
    Part # is 90142470105
    Mark..
    Cool, thanks. I'll try and get one ordered. Hopefully I can get my heater sorted and drive when it's 15 degrees in the morning without freezing.
    Stretch
    Registry # 3063
    Atlanta, GA
    What would be the correct cable for a 65 car? Thx
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
    Without benefit of the parts book I believe it is the same part number. The cables are longer than necessary so I think they also work with the more forward position of the SWB heater lever.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Yes, appears to be the same for 65.
    Banned
    Mar 2016
    USA
    does anyone know what size cable it is (its nylon covered)
    Part # listed in post 4 above.
