Results 1 to 10 of 10
Thread: FS: 71' fuchs 6Jx15 wheels
    Junior Mitglied
    Apr 2014
    California
    SOLD, THANKS EARLY911SREGISTRY!
    I'm selling a pair (2) of fuchs 6Jx15 wheels in good condition.
    The lips and pedals of each wheel is nicely polish.
    The wheels has part number 911.361.020.00 and both DC: 11/71
    These wheels are straight and true
    20150119_141620_resized.jpg20150119_141631_resized.jpg20150119_141640_resized.jpg20150119_141837_resized.jpg
    825
    Jun 2011
    Apeldoorn, The Netherlands
    Hi,
    Can you pm me for shipment to Holland.
    Thnx
    Wim
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    They look like 74 and later wheels to me.
    300359
    Junior Mitglied
    Apr 2014
    California
    Bergporsche: pm sent on shipment to Holland
    21window: I took your 'look like 74' and tried the circle late hub caps and no luck, they don't fit. Look like this pair uses the 3 prong, and they fit perfectly.
    Feb 2007
    San Diego
    With my eye I can tell they are late 71 wheels, he right, 3 prong.
    They have been polished and the sharp lip has been finessed a bit, so you are looking at it wrong.
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    Quote Originally Posted by VintageExcellen View Post
    Hmmm . Then I guess I have learned something today. I always thought flat 6"s started in 74. Always thought all cars thru 73 used deep 6"s.
    So the rennlist chart I posted with the "00" part number is wrong?
    300359
    Nuh flat 6's started as STD in 71 I believe and they had 00 part number
    Your posted chart just says early 6 x 15 were deep dish which is correct and later "flat" 6x15 had 00 part number which is correct plus later again 6 x 15 had the 10 part number from 1/75
    I would query the last bit as I am sure 74 model wheels had 10 part number too...but maybe not, they certainly were different to the previous 6 x 15's though.
    11/71 date means 72 model wheels too not 71
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    Just when you thought you knew everything about early 911's...
    Good luck with your sale. Sorry to hijack your thread a bit.
    300359
    Junior Mitglied
    Apr 2014
    California
    No worries
