Thread: Dash Wiring
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Dash Wiring
    Getting close to finishing this mess, but I need some help identifying the underdash connections. Perhaps someone can provide. I have 5 male connectors in this rat's nest that need a home. one each from from the ignition, light switch, stalk directional, stalk wiper and the hazard flasher. Using the underdash photo below, where do these connectors mate to their females? The females are two on top (interesting thought!) and three on the bottom. Labeling the two top ones left to right 1 and 2, and the three on the bottom labeled left to right 3,4 and 5, can someone provide the info? Thanks again for your help (I had labeled the parts but it went away at the paint shop)
    Name:  underdash connectors.jpg
    The harness lengths will sort of tell you where they go, the other way is to look at the color code of the wires, usually you can see some under the tape. Bottom three going right to left looking at screen should be ign. harness, turn signal hi/lo beam harness, and far left is windshield wiper switch harness. Top two one should be from light switch, I think far left, and right side one is 4 way flasher. If you plug them in wrong then stuff just won't work!! Some one of your bulkhead plugs aren't in all the way, can't see all of the rubber lip.
    Apr 2014
    New York/Florida
    Thanks Ed..... not bad from memory....appreciate the help, saves me a bunch of time
    Feb 2012
    Kolham, Groningen, The Netherlands.
    Hi, please let me know your car's type/year and i will help you!
    Feb 2012
    Light switch PIN 4 is connected to fuse 2 of top fusebox. (big red wire)
    (hazard switch) PIN 4 is connected to fuse 2 (black/red wire)
    (turn handle) has no PIN4 and PIN6. ( its the lower left on your picture)
    (wiper handle) PIN 4 to fuse 6 of top fusebox (red/white wire)
    (ignition switch) has no PIN1 (lower right on your picture
    CONNECTORS 911 1971 LHD 2013-11-27.xlsx.pdf)
