Thread: fuels lines
    Sep 2008
    Auckland , New Zealand
    fuels lines
    does the supply line from MFI pump to injector pump and return lines to the tank need to be any greater psi rating then 50? or should you use injector rate line 200psi
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    50 psi rating is plenty John, supply from pump is about two bar, and return side is less than 1 bar. Only lines from pump TO the injectors are 250 psi.
    Sep 2008
    cheers that confirms what i expected
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    Ed.....the hard lines in the tunnel TO and FROM pump and filter, I presume the larger OD line is the return and the smaller the supply...?
    Just the opposite, large is supply
