Results 1 to 2 of 2
Thread: Compression Test -- Compression Ration
    Apr 2011
    N.Calif., south of SF
    Curious, is there an obvious correlation between what a compression test results and what an engine's compression ration is?
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    No, not entirely, it's actually more dependent on cam timing/duration. The more the valves are are open, the lower the numbers will be.
