Thread: Toyo Proxes RA 1 225/50/15 on 7 R wheel
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    I just purchased some 225 Toyo RA 1 to put on a 7 R wheel. I was wondering if anybody has any experience running these on the rear of the narrowbodied car mine is a 71 911. These tires seem to run a bit wider than the average tire. I currently have 225 5015's Falken tires with no issue but they are somewhat more narrow.
    M.A.Spirito
    Depends on the car, but I suspect it's going to be tight. Better to rub on the inside than the outside when considering spacers...
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    I have a 71 t with 7r wheels all the way around. I mounted Toyo 888's 225 x 50 x 15 all the way around. 15mm spacers on the rear and 18 mm spacers on the front. I had to roll the drivers FRONT fender.
    Jan 2013
    lexington,kentucky
    Thank you that's very helpful
    M.A.Spirito
    I would suggest there is no need any more you can get the correct tyres http://www.longstonetyres.co.uk/page/porsche-911 in Pirelli P6000 or Avon CR6ZZ & the Michelin TB tyres http://www.longstonetyres.co.uk/page...-classic-tyres
