I am looking to buy some piston squirters to install in a MY 70 magnesium crankcase to aid cooling. Does anybody on the board have the part number for the correct squirters to install in this case ?
Thank you in advance.
Dave
Dave
https://www.facebook.com/Beltwerks-139610016684496/
S Registry # 1660
Le Belgique ST build.
http://www.ddk-online.com/phpBB2/vie...p?f=28&t=42628
Piston squirter part # 911-101-011-01
Thanks for the reply. Doing a search finds: 911-101-011-01 Oil Splash Tube Fits 911 78-89 928 87-91 I assume this is the only and best option available to fit in the earlier case. ?
S Registry # 1660
Hi Dave
Recently had these installed in my 67S rebuilt engine, so can ask my engine guy what he used
cheers
Mark
Alternatively, Dave, you may want to consider installing Turbo oil squirters (930.101.015.00) ...
Andy
Early 911S Reg #753
R Gruppe #105
Thanks Andy, seems you were the only guy to get my hint. I had read about the turbo one's but was not sure if they are overkill or suitable. ?
Mark, that would be great, thanks. Maybe one of the engine builders on the registry will chime in.
S Registry # 1660
As long as your oil pump is at least Turbo-spec, I think the Turbo oil squirters are worth installing - less likely to get 'clogged up' than the std squirters too.
Andy
Early 911S Reg #753
R Gruppe #105
I won't Harvey. My machinist has me doing the running around, sourcing parts etc.
S Registry # 1660
Don't use turbo squirters, too much oil. We use to remove them and install small squirters. Let a qualified machine shop install them. Gordon
