Thread: Wiper switch wire
    Wiper switch wire
    Hi all-
    The brown with silver rings wire on the wiper switch has been cut at some time. Does anyone know how long the wire should be and what terminal end it has?
    Thanks a lot in advance!
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    Feb 2012
    Kolham, Groningen, The Netherlands.
    Hi Ron, whats the part number on the switch ? is this the 901.613.302.04 ? The ends are all female 6.3mm crimp terminals.
    Brown-white is 28cm.
    Regards from Holland,
    Gerard Kroon.
    Kroon Wire Harnesses
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    It's Brown with White stipe, and is standard a switched earth.
    It should be slightly longer than the short brown earth in your photo.
    It has a normal female terminal fitted, that attaches to your horn push.
    Tony
