If you have the 901 Wevo shifter in your car could you tell me how you like it? I really like the 915 one but I've never used the 901 one they sell that goes into the 915 housing. It looks like it would be great. Let me know. Thanks, -Scott
72S, 72T now ST
I use the JWest RennShifter on my 901 and absolutely adore it. Actually I enjoy my 901 gearbox more than any other as it has a wonderfully sweet personality!
I chose the RennShifter over the Wevo shifter because it comes plug and play, without the need of a 915 shifter housing.
Keep up the speed!
Anatol
'68 911S coupe
'92 964 RS NGT
'09 987S Boxster
http://luftsick.blogspot.com - Publishing mediocre VW&Porsche pictures in the web since 1995 - https://instagram.com/terovi/
Here you go:
Keep up the speed!
Anatol
'68 911S coupe
'92 964 RS NGT
'09 987S Boxster
No, it is an OEM 915 boot. You need to cut a slot into it for the reverse lock-out. I had the shiftknob locally made be a wood artisan, using old wood, since the JWest "rose wood"-knob was not very nice. However, I used the thread from that knob for my custom knob.
Keep up the speed!
Anatol
'68 911S coupe
'92 964 RS NGT
'09 987S Boxster
Anatol,
How does the RennShifter from JWest work in the 901 w a dogleg 1st? Also, what did you do about the heater lever and cable at the front of the stock shifter?
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
Hi Mark,
the shifter is perfectly adapted to the 901 shiftpattern with the switchable lock-out for reverse preventing expensive errors at speed. As my car is from 1968, it does not have the heater lever in front of the shifter but next to the handbrake lever.
Meanwhile I have switched to the long shifter stick and added a 917 knob making it my favorite gearbox of all!
Keep up the speed!
Anatol
'68 911S coupe
'92 964 RS NGT
'09 987S Boxster
Mark Erbesfield
1957 356A #58648
Mark, the long stick gives you approx. an additional 1,5cm, putting 4th gear at an easier reach. It looks the same like the standard length.
Keep up the speed!
Anatol
'68 911S coupe
'92 964 RS NGT
'09 987S Boxster
