Thread: Removing front bumperguards
    Sep 2012
    Philadelphia, PA
    Question Removing front bumperguards
    I have a 72 T and I like the look of a smooth front bumper. How are the front bumper guards removed? will there be a gap in the trim?
    Serge
    Early S Registry #2457
    Sep 2012
    Philadelphia, PA
    Anyone who's done it before?
    Serge
    Remove the top plastic plug from the bulkhead, that gets you access to the top bolt, it may be a ribe bolt head or could be a conventional hex. The bottom guard bolt should be accessible from behind the bumper. There will be a hole there that the factory used a rubber plug to fill, there will also be a hole in the deco strip, you can either replace the deco strip or come up with a plug.
    Sep 2012
    Philadelphia, PA
    Thanks Ed, much appreciated.
    Serge
