Thread: engine case matching halves
    Senior Member pss's Avatar
    May 2014
    Netherlands
    On engine cases I always see a matching code on the top of the 2 halves, see 2 examples below.
    Is there a meaning of the codes used? Sofar I could not match it to anything reasonable and they seem to be random. Anybody know more about this?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    May 2014
    Netherlands
    bump for help on codes
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Apr 2012
    Simi Valley Ca
    Added when the two haves were married together. If you had six halves sitting on the floor, you could tell which ones went together.
    Bob B
    Quote Originally Posted by pss View Post
    On engine cases I always see a matching code on the top of the 2 halves, see 2 examples below... Is there a meaning of the codes used?
    Jacques, they are sequential pairing numbers, stamped during the machining process.
    The numbers are not coded, and have no meaning other than to identify two items machined together to create a single, separable engine case.
    Jon B.
    Vista, CA
    May 2014
    Netherlands
    Txs!! so they have a meaning but then again meaningless ;-)
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
