Results 1 to 8 of 8
Thread: Any Fibreglass guru's among us ?
    Sep 2008
    Auckland , New Zealand
    Any Fibreglass guru's among us ??
    grafting on front and rear rsr bumpers to a 73 with flares already fitted . need to cut and extend both side front and rear . as such need guru's advice and the best way forward for this work .
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Sep 2008
    and the room is quite . must be a few shop guys online
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Senior Member Scotty B's Avatar
    Jul 2012
    Charles City Va
    cut the pieces loose. Grind a bevel on all edges, inside and out. Use some metal straps with holes drilled on wither side and pop privet the two pieces into place. Cut some strips of glass and lay them up in-between the metal straps. Let them setup. Remove the metal straps ( drill out the rivets ) and glass the parts together using subsequently larger pieces of fiberglass to overlap the previous. Finish with a little bondo.
    1973 911 RSR clone..... to be
    "And pretty soon you're grabbing gears like they are ten thousand dollar bills."
    http://www.kahikocustoms.com/auto-projects
    Here's as good as it gets: http://series900.com
    From scratch:
    Early S Registry #235
    rgruppe #111
    Not a guru, but yes. On hindsight, it's always best to install flares with the bumpers so any fitting includes most of the variables.
    Here are a couple of slices I made on my RS rear bumper to prep for glass and resin.
    Sherwood
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Mark's blog might be helpful.
    Especially at the beginning he deals a lot with making his GRP stuff - so you'll have to dig through the old stuff.
    http://www.alpinabmw2002.com
    Sep 2008
    cheers , normally i have to just cut and shortern items , but the flares were already on the car with the 74 style bumpers , backdate to 73 rsr and these ones just are short. will tackle these this weekend .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Sep 2008
    Quote Originally Posted by 911pcars View Post
    Sherwood
    have you got a photo of the rs bumper on yours at the front edge ? trying to see how your fibreglass edge meets the front chassis
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
