Results 1 to 10 of 11
Thread: 901 Transaxle Parts
    901 Transaxle Parts
    I'm in the midst of disassembling a bunch of 901 transaxles
    So far I have the following available:
    901 gears:
    A 1st gear - 3pcs - includes 1st / reverse idler - $225
    F 2nd shaft and gear - $225
    GA 2nd shaft and gear - $225
    M 3rd gear - $200
    O 3rd gear - $200
    S 4th gear - $200
    V 4th gear - $200
    X 5th gear - $200
    Z 5th gear - $200
    ZA 5th gear - $200
    7:31 Ring and pinion - $350
    I also have a few 914 transaxles apart - some of the gears are the same ratio as the 901 and the 5th is a tall ZD. They are matched gears from the same transaxle, but don't have the same ink markings like the 901 gears do (more mass produced?), so I'm pricing them at $100
    914 Gears:
    A 1st gear - 3pcs - includes 1st / reverse idler - $100
    F 2nd shaft and gear $115
    N 3rd gear - $100
    V 4th gear - $100
    ZD 5th gear - $100
    7:31 ring and pinion - VW stamping - $175
    Will include the dog teeth / synchros with the gears.
    I also have a bunch of good internals like sliders, speedo drives, axle flanges, etc.
    Let me know if you need any particular item.
    Andrew M
    Senior Member Ralfy's Avatar
    Jul 2008
    Anchorage Alaska
    Pm sent.
    Senior Member Robert-Jean's Avatar
    Feb 2008
    Netherlands
    Hello Andrew,
    Interested in the ring and pinion.
    Pm sent.
    Robert
    pm sent,cheers
    Bump - took apart a few more transaxles - still have multiples of everything
    Where are these shipping from?
    I live just north of the US/Can border and ship from Minnesota once a week.
    I cross the border and file the paperwork / pay fees with US Customs and then ship via USPS out of a regional post office MN usually in a flat rate box
    Free boxes, free tracking AND cheap shipping? I love USPS
    Feb 2008
    Netherlands
    Hi Andrew,
    Thank you for the ring and pinion set, and the gear sets.
    I am very happy with it.
    Robert
    Thanks Robert!
    Bump for some reduced prices on a few gears (shipping was cheaper than I thought on the 2nd gear sets)
    I've got lots of gears and parts still
    May 2009
    Wellington, New Zealand
    Hi,
    Do you have any drive flanges for using cv joint axles on a nadella type diff. They had a larger bolt hoe down the middle I think.
    Reuben
