Results 1 to 2 of 2
Thread: pPainting and undercoating '67 911S Targa
    The structural work is almost done (thank God!) on a bare frame restoration on the 1967 911S Targa and have applied primer to body parts. And yes, I have removed the six offending dimples from the floor pan. Now comes the question of which should I spray first; the undercoating or the final paint. From what I can glean from various posts, there has been some overspray of the paint on the undercoat on some "original" cars. That would indicate that the factory would apply the undercoating before the paint. Is that the correct procedure? I do not like the idea of painting the car, than spraying the undercoat which would probably over spray onto the paint. What should I do?
    Jerry G
    "Confidence is the feeling you
    have before you fully understand
    the situation."
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Jerry when I did mine I sprayed the under coat first....I did go one step further and paint over the top in satin black, to make cleaning easier, and give an extra barrier of rust protection.
    When I handed it to my painter, I just told him where he could get a little loose whith the gun, to give that factory overspray look.
    Tony
