Thread: Solex hard fuel lines.
    Looking for a set of Solex hard fuel lines. These are the ones that run over the fan housing on the 65-66 engines. Thanks in advance for any help. Ric.
    Dec 2011
    Palm Coast, FL.
    Hi Ric, do you have a photo of the fuel line you are looking for?...I have a T fuel line if that is what you need.
    Bob
    Bob, thanks for the reply. I don't have a pic of the fuel lines I'm missing, but they are not a T. They are two steel lines that run parallel to each other and run over the front fan housing to the rt side carb.
    Senior Member CraigF's Avatar
    Jul 2013
    Nashville, TN
    Talk to Kurt and Sarah at PartsKlassik in Flagstaff, AZ. They built my T fuel line and can make you the double line from the Pierburg pump over the fan housing if you can't find one. Really reasonably priced and very accurate! http://www.partsklassik.com
    Good luck! I'm just finishing up my '65 project!!!
    Cheers!
    CraigF
    SWB, Nothing better....
    CraigF #2695
    Thanks for the tip. I will look into it.
