Results 1 to 2 of 2
Thread: 901/01 (1965) 911 engine case 902782
    I have a set of cases from a 1965 Porsche 911 available, engine number 902782. This engine case formed the basis of the engine in my 1967 Porsche 911S up until 3 months ago. The engine was stripped as I am undertaking a full restoration of the engine which will be based on a 67S engine case, therefore case 902782 is available.
    As you can see the case is in very good condition, it has a small amount of damage from an old chain failure (common) and the intergear bearing surface has a bit of wear.
    The crankcase has been modified for better air flow under the pistons.
    The case has the oil pump scavenge modification (grub screw and drilling).
    I am based in the UK but happy to arrange shipment to the US or EU. If you would like any further information or photographs, get in touch.
    I am looking for $7000 for the cases.
    Mark
    Engine case now sold, thanks Oliver
    Regards Mark
