Results 1 to 7 of 7
Thread: Mechanical Chain Tensioners
    Chain Tensioners $100.00 each
    I have two new chain tensioner Part Number 901.105.519.0R $100.00 each + shipping
    Patrick
    Oct 2010
    Southern Ca.
    What does new mean ? Is there a definition I don't know about ?
    Banned
    Nov 2004
    Scottsdale, AZ
    The definition I'm confused about is in regard to "mechanical".
    Those are hydraulic tensioners.
    But they can be repaired and made into mechanical.
    New is New or NOS. Not sure what is confusing about that. They have never been installed on a motor. The part number 519.0R shows a mechanical chain tensioner.
    $100.00 each or best offer.
    Patrick
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    First is a mechanical chain tensioner. This uses an inclined plane (screw) to adjust pressure.
    Second is a hydraulic chain tensioner which uses oil as a hydraulic fluid for pressure.
    Third is a hydraulic chain tensioner in combination with a mechanical stop collar in the event of a fluid pressure loss.
    Pictures thanks to Pelican Parts.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by Patrick 1970 1968 View Post
    Sorry dude, wherever you got that info it's incorrect. Someone is messin with definitions.
    Reminds me of this:
    One can deny that the Taliban are terrorists and instead call them an "armed insurgency" til the cows come home but they are terrorists under the accepted, historically accurate definition.
    I wish you the best of success in selling your hydraulic tensioners.
    Sorry guys when I did a search with this PN all I was coming up with was Mechanical in the description. They looked just like the Hydraulics that everyone is selling but the new ones had a new part number. Thought I had it correct and should have dug a little deeper. Thanks again for your help. Always a great site for a lesson.
    Just trying to clean out some items I do not need any longer.
    Thanks again,
    Patrick
