Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Looking For A Pretty Picture (engine electrical SWB)
    Good morning.
    I'm looking for a nice detailed photo of a "combed out" engine electrical panel from a SWB 911.
    Here's one I found but it's not giving up all of the details.
    Specifically I'd like to see what's in the "buss" area left lower foreground but happy to see one in all it's glory too!
    Tom
    Early S Registry #235
    rgruppe #111
    I will send you one if you can point out to me the seven things wrong with Ruf's car in that photo (which I took at 2005 Parade).
    John, you know I love a challenge!!
    coil sticker is at wrong end of coil
    defrost tube should be orange
    coil wire attachments should have been post and nut in that era
    regulator cover wouldn't have that decal
    and you're probably going to say it is the wrong coil (since I know you've memorized all 26,000 coil numbers!!)
    no schematic on by-pass relay cover
    engine compartment seal not tucked properly in the corner
    how did I do???
    Ed handles all my easy work... :roll eyes:
    Tom
    rgruppe #111
    Nov 2002
    San Dimas, CA
    I just happened to have a short wheelbase [1965] 911 handy:
    Name:  2015-02-09 15.05.11.jpg
    A previous owner installed a Permatune and probably disconnected the starting relay. Other than that it should be fairly original. Is this the area you wanted to see?
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Ed me telling you about Porsches is kinda like telling Noah about the Ark but here goes. . .
    coil sticker is at wrong end of coil correct
    defrost tube should be orange correct
    coil wire attachments should have been post and nut in that era correct, flachstecker not till later
    regulator cover wouldn't have that decal correct, that is a 912 sticker and the VR is wrong besides
    and you're probably going to say it is the wrong coil (since I know you've memorized all 26,000 coil numbers!!) correct. It is. I have.
    no schematic on by-pass relay cover yes, the ballast resistor relay has been repainted without the correct logo, and it's the wrong gloss besides
    engine compartment seal not tucked properly in the corner yep and I bet there is some oil hiding up in there
    how did I do???
    100% as expected Ed!
    Bonus points: Swaging on Banjo fittings isn't right. It's smart, but that's not what the Factory did. And I think that is a Mercedes Beru ballast resistor, not a Porsche one.
    Tom: Ed has done you a solid. Check your inbox for a fully copyrighted image from Monterey that I think you will be happy with.
    May 2011
    Chelsea, Québec
    Seriously impressed by the players in this game... still learning so much... thanks!!!
    Member #1616
    Sep 2013
    Kalamazoo, MI
    I need that connector in NeunElf's photo with the part # Nr 406. Anyone have a lead?
    Nov 2006
    S. F. Bay Area
    Hope this helps.....no seven-step critique needed (I'm sure there's more than that), although clearly I've added an Pertronix.
    Brian
    S Reg #1032
    Quote Originally Posted by Silverbullit View Post
    You earn bonus points for the correct coil decal :-)
