Items needed for 1965:
- air cleaner housing (left & right; I have the snorkel)
- fan housing strap (uses two M6 bolts and a nut bar)
- engine shroud pan, fits across rear of engine
- rubber band for the air cleaner
Paul Abbott
Early S Member #18
Weber service specialist
www.PerformanceOriented.com
info@PerformanceOriented.com
530.520.5816
Hav left side housing,soldthe right side for 400.00 shipped to CA. I live in British Columbia. Shipped it and it was therein four days. You can pm me or call 604 823 4536. Frankie.
I can supply the shroud pan and the fan strap with hardware
PM me for details
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Clone in Progress
Looking for right side Solex air cleaner, all other items sourced, Thanks!
Paul Abbott
Early S Member #18
530.520.5816
Hi Paul, did you find a right side Solex Air Cleaner. If not, I have one. Likely early 1965 manufacture.
Can Solex Air Cleaners be installed over Weber's without having to modify the Solex air boxes?
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
YES, It`s the aluminum plate that connects the air box to the carburetors that has to be modified / adapted to the Webers. I`m sure there is more than actually meets the eye ( height/ width etc. compared to the Solex) , but it is doable.......and looks cool &..................................... EXPENSIVE
Actually, the Solex aluminum plates should not be hacked. New ones made to order for the Weber carbs would be the way to go!
—Juan Manuel Fangio[48]
”What would PORSCHE do”
I have neither right now. Currently running Webers so will just look for an early Weber air box and be good. If I find Solex air box it would be good for future resto, but having discussed the challenges of keeping Solexes running well, this is not likely to happen anytime soon. Webers work better. If anyone HS an early Weber air filter setup they would sell, please let me know. Thx, Mark. And Happy New Year to all!
Mark Erbesfield
1957 356A #58648
