Results 1 to 10 of 10
Thread: Bendix 65?
    Bendix 65?
    This Bendix was on my 65 when I rescue it, is different from others I have seen in same MY cars. is it correct or Mexican technology was applied here. thanks for any help. Omar
    This pump is what I have seen in other cars Help!!.Name:  CIMG1083.jpg
Size:  93.5 KB What I have..
    That one is not correct, you need the other ones you have pictured.
    Thanks Ed.
    Jan 2011
    Sunny Southern France
    You'll have a hard time finding the correct Bendix.
    You can use in lieu some facet pumps, and put a sticker on it.
    Beware, the latest facet will have the electric wire in a different location. But you can find some from a few yrs ago with the wire in the correct place.
    Fitting threads might also be differents.
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by Olivier View Post
    Brad Davis at HBD Products can probably provide fittings.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    He can,,,,,and you'll need to tap out the fitting holes to 10 X 1.00 thread size to utilize his banjos.
    Apr 2012
    Simi Valley Ca
    That looks like an old Stewart Warner pump
    Bob B
    Thanks Guys, really apreciate your help on this.
