Results 1 to 10 of 11
Thread: Cibie Bi-Iode - My replica Headlight units - Chrome/Yellow
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    ++++++++++++++ THESE ARE SOLD ++++++++++++++
    Well.... It's been a couple years......but I finally found some time again to work on Cibie Bi-Iode headlight units.
    I had the Cibie 190 Bi-Iode inserts in a box for the past 3 years, waiting for some spare time to come up.....
    A new job and to many slowly progressing Porsche projects prevented me from completing this task, but I've been able to complete 3 sets.
    This is an almost new set that is made of:
    - New brass chromed trim rings (same Eric Linden has)
    - New Hella SB19 20 21 lenses
    - New lens/ring seal
    - Used, but very Nice Cibie Bi-Iode units, adjusted to fit this application
    - Original Hella SB19 outer buckets with fresh paint. (buckets have citylights)
    Please note that that in the bottom recess where the adjustment screw sits the chrome is scratched by the screw, but not visible when mounted.
    The new Hella lenses have a slightly different lettering and logo on these later productions than the early ones have
    About the Repro Bi-Iodes:
    Let me start with "they are not really repro's", but real used Cibie Bi-Iode units, just a little bigger that the original, similar in appearance:
    I've been working on converting the similar slightly bigger Citroen DS Cibie Bi-iode units and converting them is quite labour intensive, so it takes me a couple of evenings to do that the right way....and off course I have been searching for buckets, rings and glasses for a couple of months, so I can offer a complete set.
    The bigger ones won't fit into the SWB USA light inner buckets, however they do fit inside the SWB Hella USA light outer buckets. Problem with these Citroen units is that the bulb holders have very long extension made for the Citroen light housings to be able to replace the bulb from the inner front wing / wheel well. Also the mounting method is entirely different on these. I've adjusted all that on the repro's to make them fit.
    In my opinion, porsche should have used these bigger lights in the first place. There really is no benefit to use a 2nd metal bucket inside the outer bucket. (Which they did not do for the H1 and H4 lights) they even could have done without the glass on the Cibie units and use a fluted hella glass to shave off some more weight of the racers. (But it was probably a sponsor thing more than actual form follows function principle...)
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    Jan 2007
    Netherlands
    some more pictures
    Rgruppe #674
    Jan 2007
    Netherlands
    Screw scrapes and differences in the lenses
    Rgruppe #674
    Ill buy these, PM sent
    Jan 2007
    Netherlands
    Sold pending payment to Rick
    Rgruppe #674
    May 2011
    Chelsea, Québec
    what could I have sold to buy these??? so nice and would look stunning on a slate-grey car!!!
    Member #1616
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    just when you bring your kids to bed the cibies are appearing and dissapearing . .grrr.
    two weeks ago, i already missed an original 7inch set, french origin, believe it selling price for the set was 250 euro. . .
    and definitely the burner on slate gray . . .
    but stephan, the cibies for ds are cheap to get . . .but, as stated before, the don´t´fit, unless you make them fit.
    good work from our friend from the netherlands, respect . .
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    I'll take a set if 1 is available.
    Just curious, but will these fit a LWB car or are they only for SWB cars?
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Jan 2007
    Netherlands
    Quote Originally Posted by orange911 View Post
    I have a set on my LWB car
    Rgruppe #674
