I pulled the trigger and purchased my first 911 a couple of months ago. When I made the first 5 hour drive to look at the car I was a little disappointed in it's condition vs advertised condition. I didn't immediately pull the trigger as there was another car owned by a Southern Ca P shop with a great reputation I wanted to see. I was unable to see the second car as I had trouble scheduling a time to look at it, this was on me the shop/owner was professional every step of the way (Thanks again Marco). The second car sold and so I decided to further negotiate the 69T. I was able to separate the fact from fiction as the current owner had bought it to flip so his details were a bit foggy. We were able to price it correctly for both of us and it was soon on the trailer on the way home with me.
The past few months have been full of all kinds of entertainment. I was able to put 11 miles on it before I tore into it but I'm glad I did. 2 of them were before I found the advance not working correctly in the distributor the other 9 were marvelous after Jerry Woods blessed the distributor with a rebuild. But the puddle of oil in my garage meant something had to be done. I pulled the motor to reseal some of it and to figure out a few electrical gremlins. The electrical has been surprisingly straight forward and the issues have been mainly corrosion and a few broken wires. The ones that were not that easy have been solved by using the search feature (now I can rebuild a mechanical clock).
The motor however has been full of surprises. After a leak down and compression test I decided to just reseal it, (leak down was less than 3% difference and compression was at 175psi +or- all the way around). I would not need to do a top end and explore too deep at this point. As I was stripping it down to reseal the cam towers a found a non typical mix of cam chain guides and they were set up on the advanced side. The manual is a lot different than as installed and one of the cam gears were installed upside down. I also found that when the motor had been rebuilt they installed a set of Crane P-296 cams. Crane was able to e-mail me the specs so I was able to degree them properly when putting it back together. Other than that the motor has been going back together well. The "while it is out" bug did get a hold of me and I rebuild the Webers and replaced the clutch.
The pedal bushings were a little sloppy so I pulled up some of the carpet to remove the pedal cluster and found a "custom Pedal/toeboard" and a little rust in the floor that was covered with fiberglass cloth and sprayed with rubberized coating top and bottom. I honestly didn't see it while laying under the car. I removed all of the carpet and horse hair insulation. Cut the rust spots out welded in new steel. Treated the steel and painted the floor boards. I used the carpet I had as it is still in good condition and used a foil back closed cell foam backing glued to the carpet. It installed well.
There are so many more projects that I will be tackling in the near future but I figured a little update now would keep me from writing a book later. Thanks for looking.
<a href="http://s243.photobucket.com/user/lippmanf/media/Mobile%20Uploads/image-32.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff199/lippmanf/Mobile%20Uploads/image-32.jpg" border="0" alt=" photo image-32.jpg"/></a>
<a href="http://s243.photobucket.com/user/lippmanf/media/Mobile%20Uploads/1424304369.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff199/lippmanf/Mobile%20Uploads/1424304369.jpg" border="0" alt=" photo 1424304369.jpg"/></a>
<a href="http://s243.photobucket.com/user/lippmanf/media/Mobile%20Uploads/1424304373.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff199/lippmanf/Mobile%20Uploads/1424304373.jpg" border="0" alt=" photo 1424304373.jpg"/></a>
<a href="http://s243.photobucket.com/user/lippmanf/media/Mobile%20Uploads/1424304396.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff199/lippmanf/Mobile%20Uploads/1424304396.jpg" border="0" alt=" photo 1424304396.jpg"/></a>
<a href="http://s243.photobucket.com/user/lippmanf/media/Mobile%20Uploads/1424304383.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff199/lippmanf/Mobile%20Uploads/1424304383.jpg" border="0" alt=" photo 1424304383.jpg"/></a>
<a href="http://s243.photobucket.com/user/lippmanf/media/Mobile%20Uploads/1424304407.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff199/lippmanf/Mobile%20Uploads/1424304407.jpg" border="0" alt=" photo 1424304407.jpg"/></a>
<a href="http://s243.photobucket.com/user/lippmanf/media/Mobile%20Uploads/1424304402.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff199/lippmanf/Mobile%20Uploads/1424304402.jpg" border="0" alt=" photo 1424304402.jpg"/></a>
