Results 1 to 7 of 7
Thread: 1968 Differential Output shaft O ring info needed
    May 2009
    Baton Rouge, Louisiana
    Hi all
    I have a 1968 911 with a 902/0 transmission. I have a leak on one of the output seals, I have a new seal ready to go in, but when I disassembled the output flange, I learned that this flange has a aluminum cap with a fitted O ring inside. I cannot find the part no. in my book or online.
    No. 8 in the PET drawing, if fits over the cap (7) and seals the inside of the flange.
    Thanks in advance for any help in how I might obtain this part.
    Gary Cox
    Baton Rouge, Louisiana USA
    1958 356A Speedster, Silver/Black
    1967 912, Aga Blue/Black
    Aug 2009
    SF Bay Area
    Your trans does not have a aluminum cap. You Have nothing to worry about. You are looking at a parts diagram of a 67 trans, not a 68.
    Jim
    May 2009
    Mine does have the cap and O ring, its sitting on my work bench, I would like to change the O ring as well as the seal, but can't find a part no. or a source?
    Gary
    Gary Cox
    Aug 2009
    SF Bay Area
    You have a 67 trans. The O ring can be sourced by size and the flange seal is readily available through the usual suspects.
    Jim
    May 2009
    Thanks JimmyT, that is what I needed, and sorry I forgot to search for old posts, I do know search is my friend!!
    Gary Cox
    Oct 2010
    Southern Ca.
    Jim is incorrect . There were '68's that left the factory with transaxles with this o ring .
