Hi!
I read many threads about engine shroud restoration, but i couldn't find the right method to restore the green shroud of my 1969 911E. The shroud has some cracks so it needs some repair. After that it shuld be recolored somehow to be as close to concours as possible. The first thing is i can't decide to spray it with gel coat or repaint it? Or is there any other method? Dye can't be a solution because of the repaired cracks (i used fiberglass and than sanded back). Can somebody tell me a RAL color code for the green color (i know it can't be the same but can be close)?
