Thread: Help with facet pump needed.
    Oct 2010
    Denmark
    Hi
    I took my Facet ( bendix look alike ) a part to check the filter... so all those part came out, can someone tell me if the piston with the magnet in one end have to go up in the pump with the magnet first or with the magnet downward against the filter? the other end of the piston is hollow.
    I also think the parts inside look strange compared to other facet pumps? when I bought it, it was yellow zink outside incl. the sticker fitted, bought from ebay , seller from australian.
    I have painted it silver.
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Junior Member
    Jan 2010
    Ann Arbor
    You may be to find a parts diagram online.
    Oct 2010
    Denmark
    Have been looking but no luck.
    rg.Lars
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    See if this helps.
    Oct 2010
    Denmark
    sorry, this drawing do not match my pump internal parts , se my pics.
    Lars
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Nov 2014
    Port Orange, FL
    Aircraft Spruce (AircraftSpruce.com) sells new Facet pumps for less than $100. My advice: buy a new one, as it appears that you are missing a retaining ring which prevents the internals from falling out. There are also at least two types of filter: a fine mesh type and a porous cylinder, which can become fouled and impossible to clean.
