Thread: FS: New cloth wrapped fuel line
    SOLD ---- Left over from when I replaced all the rubber lines. I believe this is used for the cold start system on an MFI
    4 mm outside diameter
    2.5 mm inside diameter
    Have about 4 meters of this in the coil
    $30
    Still available
    still availlable
    I will take 1 meter for 10$
    Can anyone confirm whether this is the correct fuel line for the cold start, and whether the color should be red? I'm re-doing my 69 MFI air cleaner now. If this is correct, I'll take a meter for $10 also...Thanks Steve
    1969 911 E #824
    I too have a '69 E and would like enough to put on my car. Sounds like a meter (?)
    Kindly let me know.
    Rich
