Results 1 to 2 of 2
Thread: Back Light and Bridge/Bypass switches Sportomatic
    May 2013
    Canterbury, UK
    Smile Back Light and Bridge/Bypass switches Sportomatic
    I am having trouble with my Back Light switch on my 1968 911L. Fails to work intermittently which means the starter is not powered when you turn the ignition key to start it. Usually corrected by moving the shift lever in and out of Park/etc. The reversing light also only works intermittently. Part of problem may be the 4 pin connector.
    Interested in any feedback.
    Graham
    UK
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    What, no comment from Frank "God gave man a third leg so he could use a clutch" Beck? Someone want to check he is still alive?
    Is this what you are looking for?
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
