Thread: FS: Original 67S Pistons and Cylinders, and Cylinder Heads
    Sep 2010
    Allentown, Pa
    For sale is one complete set of original 1967 911S cylinder heads, date stamped 8-66. The casting number reads R901.104.305.02. This set of cylinder heads will need to be rebuilt prior to installation. The used valves, springs, keepers and shims are included. All parts have been ultrasonically cleaned and inspected. There are no cracks or any major defects. The intake valves measure 42mm and the exhaust valves measure 38mm. The valve seats are in nice shape, but the guides show some wear.
    Asking $3800.00 plus shipping.
    Also for sale is one set of original 1967-69 911S pistons and cylinders, including new piston rings. The original used wristpins and clips are also included. These pistons and cylinders have also been ultrasonically cleaned, honed, inspected, measured and spec’d. They are ready to be installed and used. One of the cylinder walls has a small area at the base of the cylinder that was rusted at some point in time. This does not affect the sealing area of the piston rings and the cylinder overall is unaffected. There is also a small crack in one of the top fins of one of the cylinders, as you can see in the photos.
    The compression ratio for these pistons and cylinders is 9.8:1, with a bore of 80mm. All of the piston specs are available upon request and are within the factory’s spec.
    SOLD
    Located in Allentown PA.
    PHOTO ALBUMS:
    1967S Cylinder Heads
    1967-69S Pistons & Cylinders
    Pm sent. Thanks
    PM sent on P&C's
    Tom
    Mark,
    Ultrasonic cleaning alone accomplished this level of clean? Who did the work? I am interested in their service.
    thanks!
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Sep 2010
    Allentown, Pa
    Neil, PM sent.
