Results 1 to 10 of 13
Thread: fuel tanks; SWB & LWB the same ?
    Mar 2004
    Castro Valley, Ca.
    can I install a fuel tank from a SWB (carburetor) car into one w/ MFI ? I seem to recall something about an extra port in the MFI tank ?
    any help appreciated.
    thanks
    jerry
    1940 Mercury town sedan
    Nov 2002
    San Dimas, CA
    In 1969, the first year of MFI, the part number for the standard 62 liter tank changed from 901.201.010.21 to 901.201.010.22.
    I'm not an expert on Porsche MFI or the associated tanks, but many fuel injection systems do run a return line back to the fuel tank.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    If this schematic is correct it appears that only two ports are needed for the system. maybe one of the experts has more definitive info about the third port shown.Name:  images.jpg
    I believe the the vent fitting is smaller on the SWB tank. The SWB tank will have two fittings, one was for the Webasto. The LWB tank has three; discharge, return, and Webasto.
    Oct 2010
    Stockholm/Sweden
    + 1 on Ed's comment
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Aug 2009
    SF Bay Area
    Ed is spot on, as usual.
    Jim
    Feb 2003
    Los Angeles
    Helpful information.
    Will a carburated 911T have a return line in the tunnel or does one have to install one if your changing to an MFI engine?
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Depends on the year of the T. If 69-70 with front mount pump the return just went from the pump back to the tank. If 71 and later with rear mount pump then there was a return line in the tunnel. The return circuit however was only from the pump back to the tank
    Apr 2014
    New York/Florida
    That is a good question.
    I' m not sure whether my 72 was carbureted originally or not, but it has both supply and return hard lines in the tunnel. The fuel pump mounting support piece (welded to the torsion bar tube) is missing, and I don't believe it is available. So confusion reigns. I had thought that the right approach would be to relocate the fuel pump to the front a la SC and later models, but maybe a better approach is to fashion a support piece and mount it by welding or bolt to the underside in the area where the factory intended it to go. Ed said he could provide a photo of the correct mounting in place.
    Here's your pictures of the pump mount. The part number is 911-501-023-01. You should try to get one through your dealer, it's often amazing what is still in the parts supply. Since this is welded to the torsion bar housing someone had to seriously want it off since that would have involved a lot of cutting.
