Results 1 to 10 of 14
Thread: Custom JE pistons. ??
    Sep 2009
    UK
    I am looking to buy a set of 85mm 10.5.1. high compression JE pistons for my 2.3 short stroke ST motor.
    Will i need to provide any other information or will they know what i am after.
    Anybody ordered a set of these lately.? A reference or part number would be a great help. As i am over the pond, i don't want to get this order wrong.
    Thanks in advance
    Dave
    Nov 2006
    S. F. Bay Area
    Haven't ordered such, but have had pistons made.
    Believe JE has a custom piston order form that you and/or your motor builder can fill out completely. That may help get you the right parts. HTH, Brian
    Brian
    S Reg #1032
    Sep 2009
    UK
    Thanks for the reply Brian. Hope someone has been up this road and can supply a spec or order number.
    Oct 2010
    Southern Ca.
    Why not use Wossner pistons ? I believe they have 85's 10.5 's in stock . They use the same alloy as the Mahle 2.2 S's .
    When I did it ten years ago they wanted to know something about wrist pin positioning as well as the bore dimensions. And we needed to ourselves mill a couple thousandths off the outside top edge to avoid hitting the heads. You want someone who knows what he is doing filling out those forms to avoid disappointing and expensive results.
    jhtaylor
    santa barbara
    Sep 2009
    UK
    Thanks for the reply's guys. Looks like the Wossner is a plug and play with all the homework done for you. Why JE don't do that i don't know.
    I am going with the Germans.
    May 2005
    Oroville, CA
    In my experience, ordering JE pistons are really made for a wholesaler not really for direct to the public. All the JE's that I have ordered through a dealer were plug and play also....
    I trust the engine expert that I order through to get it right and he does...Like Taylor said try to avoid the expensive and disappointing result of a miss-order...
    H
    Aug 2005
    VA
    I have ordered 9.5/1 85 mm JE's. Just tell them what it's for, what CR and they will send them to you. The two pictured are both 9.5/1. The dirty one is an older design, apparently.
    Chris
    73 911E
    Jan 2011
    Sunny Southern France
    There's something I am missing here.
    How can you order "off the shelf" pistons for a give CR, without actualy knowing your head's volume?
    No first hand experience with porsche's head, but given the valves diameter, even a small grind on your valve seats will affect your head's volume, thus the expected CR. Am I wrong???
    If I am correct, you would like your engine builder to be able to "cut" the pistons to size to accomodate the expected CR with your heads.
    If I were you I'd be carefull with my $$$, just in order not to be disapointed....
    Olivier.
    Sep 2009
    UK
    Olivier,
    this is what i am learning. I think piston work will be required. As well as the head volume, and head skim. The decks have also been flycut. These factors all affect CR.
