Results 1 to 7 of 7
Thread: Nadella to Lobro conversion A to Z
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    I want to drive my 911 more often and longer distances this spring and summer but am concerned about a possible unexpected self destruction of my Nadella axles. They appear in fine shape but still.....
    I looked through our site for a step by step guide but could not find one, so I could use some help from our resident experts here. I am a decent wrench and have access to even better help but will need a complete parts list and step by step instructions. Transmission is a 902 5-speed circa 3rd quarter 1965.
    Anyone here want to lend me a virtual hand?
    Thanks in advance!
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
    Aug 2009
    SF Bay Area
    Here are the major pieces. You will need the special bolt, washer, grease cap and retaining clip, as well. I can do a complete axle changeover in less than an hour, but I have had a bit of practice.
    Jim
    Jim, the expansion bolts and washers are the same, he can re-use what he has for a Löbro conversion.
    Jon B.
    Vista, CA
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
    Jon
    Of course, you are correct. I don't know what I was thinking. One would only need the grease cap and retainer. Someone on this forum makes an improved version over the original Porsche part. The conversion axle flanges (like the one in my picture) were used for just one year (1967). Nothing else will work.
    Jim
    Senior Member Christian Guthrie's Avatar
    Jun 2011
    Arizona
    Hi Jim
    Can you post a better picture of the conversion axle flange for reference?
    Jan 2013
    Shenandoah Valley
    Thanks Jim and Jon! Could you further describe the one-year-only parts and what makes them unique? I will need to start my search for these parts and would like to verify I am getting the correct ones.
    Or does EASY have a serviceable set of these parts available?
    Alex in Virginia
    Looking for:
    Aug 2009
    SF Bay Area
    Quote Originally Posted by VA_alfa View Post
    Alex
    The correct flange is among these flanges.
    Which one is it?
    It should be pretty easy considering that I have already posted a pic of the one and only flange that will fit.
    Jim
    Should I really post detailed pictures and educate all of the amateur entrepreneurs?
    Yes, EASY has all the parts
