Thread: Bleeding rear Caliper
    Oct 2010
    Denmark
    On the rear calipers on my 67 there are 2 bleeding points on each caliper, which to take first , to avoid air? the inner one against the engine or the outer one against the Wheel?
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Always do the inner first, outer last since that is the furthest point that air gets to.
    I've heard go furthest to nearest and nearest to furthest. I don't think it makes a difference therefore. I usually do furthest to nearest in terms of caliper order and bleeders.
