Results 1 to 10 of 12
Thread: WTB: aluminum acorn nuts for 67 engine grille
    Well John A's post got me going so I am attempting to disassemble my 67 engine grille and so far found it a challenge to free up the nuts. I have discovered that applying too much heat makes the top of the nut actually explode ( they are hollow and heating the trapped air makes for expansion with no place to go but BANG). I would like to source new acorn nuts. I could swear someone was selling these a few years ago. Any help would be appreciated. By the way there over 100 individual parts to these grilles and they dont just come apart with a little wd40. John's price for restoration is already starting to look like a deal
    Skip
    still looking.........................
    did you check with stoddard?
    I also recall seeing them for sale somewhere recently...
    ds
    I havent checked with Stoddard, I will post what I find out tomorrow. Thanks for the lead.
    Stoddard was a no go. They said they haven't had the grilles or parts for years
    Quote Originally Posted by CarmelSkip View Post
    Darn...
    But I'm pretty sure that I have seen these somewhere recently...
    Serria Madre was advertising the grilles recently.
    If nowhere else, perhaps a hardware specialty store. Maybe like McMaster-Carr or Grainger?
    Have to admit to guessing at this point.
    Ds
    Its a pretty oddball part when you take a close look, not quite a typical acorn nut. There is a specialty metric hardware shop in the SF Bay area that is worth a try. I left them a message and should here back tomorrow but I'm kind of doubtful they have a match. ( They called back, dont have them). Looks like an opportunity out there for some one to source these.
    Last edited by CarmelSkip; 05-09-2015 at 06:19 AM. Reason: update response from supplier
    Those nuts are DIN 986. What diameter is needed?
    I doubt you will find alum material, but stainless is available.
    M-6 is in stock p/n 900-085-003-02 which is steel, clear zinc http://www.stoddard.com/900-085-003-02.html
    Uses a 7mm socket, the profile of the Stoddard part looks pretty close but the hex section looks to be taller on the original.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Have you tried Ace hard ware?
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
