Thread: 2.2p/s versus 2.4p/s
    Okay probably a stupid question but
    I am having a 2.2 E motor redone but I need piston and cylinders.
    Everything is E but I happened across 5, yes 5 Pistons and cylinders right down the street that are original Mahle but they are from a 2.4.
    Question is can they be used with 2.2 E heads, cam etc.
    Apr 2010
    Kalimantan <SeaTac<Philly
    Stock 2.2 will be higher compression and prefered. 2.4 stock will be lower compression, so check what type.
    They are S Pistons so where does that leave me proformance wise
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Baxter2012 View Post
    Way down on compression on 1 cylinder
