Thread: ST Style Roll Bar Wanted, and a couple '72 parts.
    Swedewerks Survivor Cars SD Swede's Avatar
    Jan 2014
    Florence, OR
    Anyone have a simple bolt in ST, (behind front seats only) style roll bar they no longer want? Needs to fit '72, non-sunrof, coupe. I'd prefer to be able to pick up in So Cal area.
    Other parts found
    Thanks guys,
    Pete
    Peter Andersson #2864
    Pinstriped Early 911 Club #1
    What kind of sway bars are you looking for?
    Jan 2014
    Florence, OR
    I'm still looking for the roll bar...
    TRE makes a pretty good one.... one's in my car
    http://www.tremotorsports.com/product.cfm?Node=33
    Be sure to specify a non-sun roof bar........
    Hope this helps,
    cm
    Jan 2014
    Florence, OR
    Thanks Chuck...after the research I've done it will be TRE or Autopower (close to me in SD) I'll go with. I've seen yours, always from behind, and I like it!
    Senior Member Sixtyseven911's Avatar
    Feb 2015
    Los Angeles
    Ditto on TRE. They're making a production run now so get your hat in the ring!
