Mechanically well sorted Targa with minor needs......
Note: Modified Ad from late 2014:
1983 SC Targa 3.6 Varioram conversion is back on the market.
Regulars to the Pelican site may recognize this as the "Moses Targa", which has many threads dedicated to its high-quality, no expense spared build. I (Luke) am the fourth owner of this car, purchased from Rob end of 2014.
From Previous owner: "I would not hesitate to drive it anywhere -- arguably one of the most sorted, well done 3.6 conversion cars out there. The car is happy in traffic, around town or on weekend coffee run blasts to the middle of nowhere. The engine pulls strong in all gears and sounds absolutely incredible. No rust or accidents. Excercised regularly on the weekends, always garaged and obsessed over. Just an awesome car. Certainly not concours, but excellent driver and priced accordingly.
105K on the chassis, approximately 67K on the engine (not sure of true mileage).
The car recently had a full PPI at ROCS Auto in Belleville, NJ. Excellent leakdown numbers of 2.5 - 3.5% across all cylinders."
Summary below:
NEW PRICE $35,000.
Thread on suspension build by Tyson S:
http://forums.pelicanparts.com/porsc...l-touches.html
Exterior:
Beautiful Factory Zinn Metallic (code 956). The car was treated to a high quality, windows out repaint prior to my ownership.
Usual stone chips on the hood and front bumper, a few scratches on the body which the pictures will show. Overall, paint a 8 of 10, it looks fantastic. The rear fender was damaged by the PO's fence and was properly repaired shortly after I received it.
GT Racing Front and rear IROC-style bumpers. The front bumper was replaced in 2012 after being backed into by a careless driver when parked. The new bumper is slightly warped where it meets the hood, I have a 964 smile that will come with the car to remedy this.
Factory Carrera Wing
Bosch Euro H4 conversion with Sucro relay kit
993 aero mirrors
Interior:
Cobra Misano seats -- Nappa leather with carbon fiber shelled backs. Fully adjustable and tilt for access to rear seating area.
Factory seat belts and receptacles for everyday driving
Schroth 4 point harnesses removed are included, labels are expired
TRE Targa harness bar.
Momo Prototipo steering wheel
Rennline pedals and dead pedal
All gauges work properly including the clock -- note it has a 930 tachometer
Rear seat backs currently not installed but will come with the car
Wevo Classic Shifter
Engine/trans:
1997 3.6-liter from C4S (installed in 2005 with 45K miles). Engine has approximately 67K, but not certain of actual mileage. Engine uses about 1 quart every 1000 miles of spirited driving. No smoking or major leaks.
Patrick motorsports conversion kit with lightweight flywheel
Sachs power clutch
B&B polished stainless headers with heat -- sounds incredible!!!
High performance cats - car came from California will pass emissions!
Custom Dynomax stainless muffer with dual outlets
Cytex chip
Carbon Fiber RS heater Tube
B&B front oil cooler -- car runs 180 degrees all day long
Elephant Carrera fender cooler with fan
Elephant oil lines
K&N air filer
New rear axle assemblies in 2013
915 trans with open differential and stock gearing -- shifts great
Wheels and tires:
17" (7.5F x 9.0R) Rota Fox wheels in hyperblack
Recent Dunlop Direzza Z1 (215F, 255R)
Suspension:
Smart adjustable 23mm front swaybar: Carrera G50 style rear bar
Turbo tie rods
Rack spacer kit
Elephant monoballs
Elephant polybronze control arm bearings
Elephant Polybronze rear Spring plate bushings
22mm front and 28mm rear torsion bars with reinforced mounts
Reinforced front struts with Koni Sport adjustable front inserts; Koni Sport adjustable rear shocks
Control arms modified to accept 993/964 brake deflectors -- currently not installed.
Rennline triangulated front strut brace -- tied-in under master cylinder
Brakes:
Brembo GTP brake kit, F/R -- (Ferrari F40 front, Lotus Esprit V8 rear)
25mm 930 master cylinder
Brake fluid flushed in 2013
Minor issues:
Radio does not work: Pioneer stereo & MB Quart speakers with removable faceplate installed
No radio antenna
Some scratches and stone chips on the hood.
Minor bubbling of the paint on the rear bumper, caused by exhaust heat
Bezel for the fresh air blower is cracked, replacement with cables that will come with the car
Targa top is showing its age, No leaks but needs a rebuild -- this is factored into the asking price.
2 small stress cracks in decklid grille.
Engine leaves a dime sized drop of oil after a drive, nothing more, nothing less.
Car will comes with many extra parts and a custom car cover.
Possible elegant Update: The "bridger" Version.....
This is a very well sorted car that needs a long term owner to appreciate it......
LukeMaranoJr@PhilaMacaroni.com
