Results 1 to 10 of 11
Thread: Sound Deadening
    Senior Member sebastianroher's Avatar
    Jan 2015
    Florida
    Sound Deadening
    Has anyone used this? If so, what did you think about it? I've almost gotten all of my old material out and I need to get it replaced. I'm open to other suggestions but I'm thinking this might be the ticket. Thanks!
    http://www.autoatlanta.com/Porsche-W...RWU890100.html
    Sebastian
    1971 911t coupe
    2002 Camaro z/28
    Jan 2015
    Florida
    Forgot to post the link to the product. Edited!
    1971 911t coupe
    2002 Camaro z/28
    interesting - I wonder how well it works
    I'd scrap all the old stuff off; cover 25% of each panel with a dampening material; then get some MLV with foam on it and cover everything with that - tape the edges & seams - let no gaps show
    that is the std. way to do it but might add weight
    I've used the Wurth stuff, in fact I think I posted a picture of it, I think it works great, easy to install and form.
    Jan 2015
    Florida
    Ed, can you post pics? Did you use a heat gun to get the job done? Thanks.
    Sebastian
    1971 911t coupe
    2002 Camaro z/28
    Pictures are on your thread post 111. No, a heat gun was not necessary.
    Jan 2015
    Florida
    Ed, do you remember how many panels you used altogether to cover the car? Thanks.
    1971 911t coupe
    2002 Camaro z/28
    It was several years ago, but I think I used two packs of panels.
    Oct 2010
    Florida
    I used it last year.
    I removed all of the sound deadener about 10 years ago when this was a track car. That was a nasty job.
    It takes a while to trim the Wurth stuff to fit but it's worth the effort.
    Richard Newton
    will it work on the firewall?
