Results 1 to 10 of 14
Thread: 911 Engine What year?
    I have a complete 911 engine 900484 that came out of a 1969 modified 912. I am trying to figure out if it is for a 1965 model year or a 1966 model year any info would be helpful.
    You you have a very early 901/01 engine fitted in 911 cars up until March 1966 when Weber carbs replaced Solexs. Chances are good that it was originally fitted in a 65 model. Hope that helps
    John Schiavone
    Connecticut
    Senior Member 993TT's Avatar
    Apr 2013
    Europe
    Very early 65 (late Jan-early Feb). Does it still have Solexes?
    Timo
    "There's no point living if you can't feel alive"
    - a few 911s & some others
    Early 911S Registry #3206
    The engine has Weber carbs on it now
    Oct 2011
    The land of fruits and Nuts
    Still creme de la creme Dirk. I hope you find its original mate. If you do, you can surely purchase a hot rod motor for the 912. There are always a few guys looking for early motors for their '65s
    Porsche taste on a Volkswagen budget...
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by John912 View Post
    The little spec booklet gives the date of the last Solex-carbureted engine as 21 February 1966 (engine # 903910). Other unique features of the earliest engines are center lubricated camshafts (used up to engine #903069) and forged steel rocker arms.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Dec 2003
    West Los Angeles
    Quote Originally Posted by Dirkster59 View Post
    My guess is engine #900484 was manufactured in the first week of January 1965. The nearest match to that engine number that I've recorded from forums is 900469, which is associated with chassis #300411.
    If you haven't heard from a couple well known builders/restorers yet, expect to get PMs.
    techweenie.com
    Quote Originally Posted by Eminence Gris View Post
    Well considering that he posted 3 different places about the motor with almost no replies for a day or two I would say his inbox is just about full
    Dec 2003
    West Los Angeles
    Quote Originally Posted by P-CarLover View Post
    The Usual Suspects are always alert. :-)
    techweenie.com
    Thank you one and all for the info and the help-now the hard part what is it worth?
