Thread: COA does not give build date. Any one close to 9112301129 ?
    I would at least like to approximate the date.
    Thank you
    Sep 2013
    Vancouver, WA
    Check the build date of your clock. If the clock is original it will be dated 1 month prior most likely. My 1/72 built T was probably a late Jan build as I met a person who has a T coupe built 150 cars before mine and they were also a 1/72 build. My clock is dated 12/71 as are most of my gauges although my tach is 11/71. My fuel sending unit is also 2 months prior at 11/71.
    As far as your S goes, you have coupe number 1129 out of 1750 coupes made in '72. I'll stab at April of '71. Let us know what you find out.
    Good stab there Gearby. (I assume your stab meant to be April of '72 not '71) Four of my gauges are 3/72 clock included so I'll go with your April of 72.
    Thanks for the heads up.
    Sep 2013
    Vancouver, WA
    oops, yes, April of '72.
