Results 1 to 9 of 9
Thread: FS: 2.7L Twin Plug Engine
    Up for sale is a 2.7L twin plug engine. It is available as a complete motor – from air box to exhaust flanges (no muffler, but flywheel and clutch ARE included) – or as a long block. It is currently installed in my client’s 72T hotrod, but he no longer has a need for this motor. Compression and leak down numbers available upon request.
    The motor was built approximately 5 ½ years ago and has covered approximately 7500mi in that time. TLG did not build this motor, and there are no build records available beyond what the client has told me. The car spent a few years in Europe, and when it returned I pulled the motor/trans and disassembled the car. During that time – about a year or so ago – I took the motor down to a long block and sorted the fuel injection and ignition issues, stopped various oil leaks, adjusted the valves, and re-dressed the motor. It is an absolutely fantastic runner and is a pleasure to drive; this is a VERY good example of what a 2.7L engine should be.
    Engine Size: 2.7L
    Case: 7R
    Compression Ratio: unknown
    Case Mods: shuffle pinned; case savers; oil bypass modification
    Crankshaft: standard/standard
    Rods: Stock w/ARP hardware
    Pistons: Mahle
    Oil Pump: 3.0L or 3.2L
    Intake Ports: 37mm
    Valve Train: Aasco springs w/titanium retainers
    Camshafts: DC60
    Distributor: Burn Bros. Twin Plug
    MFI: 2.4T modified to suit current application; injection pump warm-up regulator replaced with manual rack adjustment set to “warm” position
    Exhaust: European Headers by George
    Fan Shroud: Series900 amber fiberglass
    226mm Fan & Housing: Restored by Mark Mottshagen
    Complete engine: $27,000 obo
    Long block: $20,000 obo
    For more information please contact me directly at: TLG_Porsche@yahoo.com
    NOTE: Photos taken prior to removal of heat. Motor currently fitted with block-off plates and headers. Additional photos to follow...
    -Marco
    TLG Auto: Website
    More pictures
    -Marco
    TLG Auto: Website
    May 2009
    West LA
    What engine took the place of the one for sale?
    Registry Member #1583
    Quote Originally Posted by popowitz View Post
    I'm sorry, Dave. I'm not at liberty to disclose that information at this time...
    -Marco
    TLG Auto: Website
    Senior Member Fubawu's Avatar
    May 2013
    Marco do you have any dyno numbers? Do you happen to know who built it?
    Cheers
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Quote Originally Posted by Fubawu View Post
    Cheers
    I don't have a dyno sheet on the motor, but it was initially assembled by Tyson Schmidt.
    -Marco
    TLG Auto: Website
    Up to the top.
    -Marco
    TLG Auto: Website
    Engine still available.
    Price is somewhat negotiable ... reasonable offers will be entertained.
    -Marco
    TLG Auto: Website
    Sale pending
    -Marco
    TLG Auto: Website
