Results 1 to 2 of 2
Thread: Brake fluid
    Brake fluid
    Hi again
    I am restoring a 1974 Porsche 911 and the previous owner have made some changes.
    Where can i find, or see where passes the brake fluid pipes from the brake fluid reservoir into the brakes? The direction that i need is from the reservoir into under the car, to know where they origanlly passes.
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    If I understand your question correctly, remove the pedal board, (board behind pedal assembly) and they pass through the interior there through the floor into the master cylinder.
    Hope that helps..
    http://www.autoatlanta.com/porsche-p...section=604-00
    Mark..
