Thread: 1965 1966 only engine fan assy
    Feb 2007
    San Diego
    this is a 65-66 only aluminum ring with the large mag fan. This is correct for 65-66 and very hard to find. Fan has no damage, no cracks, no chipped fins - where else you gonna find that? The large diameter means you can not put a later fan into the aluminum ring - won't fit. Small hole drilled in fan ring see picture.
    $1200
    Nov 2011
    Bluffton, SC
    Pm sent
    C
    Feb 2007
    San Diego
    sold, off to Germany
