Results 1 to 7 of 7
Thread: swb Rear wheel bearing spacer
    Oct 2010
    Denmark
    The two bearing on swb cars are seperated by a spacer tube with two holes and a flat side. I need help to place the spacer tube correct again when replacing the inner and outer bearing.
    Does the flat side point downwards against the hub face or?
    more about the matter here: http://www.early911sregistry.org/for...=inner+bearing
    thanks
    lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Oct 2010
    Denmark
    anyone who knows how to place the tube correct?
    rg.Lars
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    The factory manual says place the flanged end toward the inner bearing.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Oct 2010
    Denmark
    thanks Mark, what is ment by "flanged"?
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Nov 2006
    S. F. Bay Area
    Look at the spacer. You'll notice one end is a bit 'larger' and has a 'lip' machined in. That is the 'flanged' end.
    Brian
    S Reg #1032
    As Brian said....the flange on one end is about 1mm high and 5mm deep....that goes toward the inner bearing.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Oct 2010
    Denmark
    Thanks guys
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
