Results 1 to 10 of 18
Thread: 902/1 trans serial # look up help
    Can one of you fella's help me identify this box #227399 902/1
    Thanks in advance
    Todd
    Nov 2002
    San Dimas, CA
    I'm not sure how much help this is, but here's the transmission chart from the little Spec Booklet:
    I don't see a range here that contains #227399
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    TTT ..... Anyone ????
    Dec 2011
    Victorville CA
    That's a 65-67 911/912 5 speed with A F M S X gearing and 7:31 R&P. At least that's what this chart says. I also don't see that range in serial #'s
    http://www.blueskymotorsports.com/in...id=17&Itemid=6
    Nov 2002
    San Dimas, CA
    The serial number ranges the spec booklet gives for the 902/1 (as opposed to the 902/01) are:
    • 220001 - 221721 (to 26 Jul 65)
    • 234001 - 238942 (4cyl engine)
    • 130001 - 131571 (6cyl engine)
    Numbers from 68-Model
    • 3280001 - 3289999
    Porsche's tables for SWB 911s are often not so easy to interpret. About all I can deduce for #227399 is it probably came after 26 July 1965.
    The gear ratios are:
    1st A 3.09:1
    2nd F 1.89:1
    3rd M 1.32:1
    4th S 1.04:1
    5th X 0.86:1
    Ring & Pinion 4.43:1
    Jim Alton
    Torrance, CA
    May 2005
    Oroville, CA
    Do You have a photo of the serial number. Sometimes a 1 looks like a 7.
    It would make sense if it is....
    H
    Quote Originally Posted by TB73 View Post
    Thanks in advance
    Todd
    It's an 902/1 transmission that was used in a car in the month of January 66. Could have been a 911 or 912. If it was a 911 it's in the 3035XX - 3036XX range.
    Richard
    Quote Originally Posted by NeunElf View Post
    This little specs is either not complete (like printed in 65) or has a flaw. The 901/01 and 902/1 transmission for the cars after the summer of 65 are not in there.
    Richard
    Transmission serial numbers for the 1966 model year were not well documented by Porsche, for some reason.
    Numbers like yours come up that do not appear on any list from Porsche.
    For 1966 model 902/1 transmissions, that serial number range is roughly from 221722 to 233999, for both 911 and 912 cars.
    We discussed this same topic here:
    http://www.early911sregistry.org/for...-8-65-question
    Jon B.
    Vista, CA
    Jul 2014
    Niagara, Ontario
    My 66 911, January 25, 1966 has the 902/1 with serial 227126.
    Yours should be close,
    Mike
