Results 1 to 10 of 11
Thread: Mahle 2.4S Pistons and Cylinders
    Senior Member steve1rob2's Avatar
    Cocoa, FL
    SOLD!
    Complete set of 6 2.4S Mahle Pistons and Cylinders used pulled from my 73 that we decided to turn in to a 2.7RS Clone with Spec motor. Pistons are like new. Cylinders show some wear. A few bent fins and a couple have cracks or are broken. Internally not bad but might need a little work. Includes wrist pins. Harder and harder to find. $850 shipped in Cont US.
    Steve
    64 356 C Coupe
    68 Coupe
    70 S Targa
    73 RS Clone (73 T)
    73 914 2.0
    01 Boxster S
    06 Cayenne S
    67 S Light Ivory Coupe (Prior), 67 912 Coupe (Prior),
    68 912 SWT (Prior), 71 T Targa (Prior),86 Carrera Targa (Prior),
    87 930 Coupe (Prior), 93 964 Cab, 96 993 Coupe (Prior)
    88 930 Slant Nose Coupe (Prior), 92 968 Coupe (Prior), 73 914 2.0 (Prior)
    S Registry #1402
    Hi,
    PM sent.
    Micke
    Cocoa, FL
    I guess Mikael passed. Still available. Thanks.
    Steve
    Cocoa, FL
    These need to go. Price lowered above.
    Steve
    Does they fit a 2.2 911T from 1970?
    Im interested in some more horsepower on my 1970 911. Is it p&p? Or do I need other parts? Thanks Rasmus
    Cocoa, FL
    I am sure others on here no more than I do. Yes you can R&R your P&Cs with these for more displacement, however you will need to adjust your carbs to account for that displacement. To really benefit from the change you would need to swap cams, open up your ports and upgrade your carb setup. Anyone want to pipe in?
    Steve
    Cocoa, FL
    price lowered above. Thanks.
    Steve
    Senior Member tonizzos's Avatar
    Mar 2012
    Luxembourg
    send a PM
    steve
    Mar 2012
    Luxembourg
    very nice contact but will pass
    steve
    Cocoa, FL
    price dropped above. Thanks.
    Steve
