Thread: FS: Un-Simplified Diff
    I have a few un-simplified diffs from 70 and 71 911 transaxles for sale
    These are the diffs that don't use the bolts with nipples that can fail.
    Basically, you can take out your current 70/71 simplified diff and swap the internal parts from this one to make yours non-simplified and drop it back in.
    Some of the parts can be used on earlier diffs, but the gears were a bit smaller so it's not a direct swap of internals.
    Included is the 70/71diff carrier and internals + the 2 flange bolts with no nipples
    Looking for $125 shipped per setup
    Andrew M
    Jun 2010
    Garden State
    I'll take one if it can be modified to fit '69.
    A sample pics - I have ab out 5-6 diffs and bolts left
    G69 - sent you a PM
    Andrew M
